Lite-PA System
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
JTR NOESIS 210 RT - L/R mains
Chase SHO-10 - Center
Chase PRO-10 - Surrounds
Vizio E550VL
A co-worker has asked me to help his girl with a business system. It'll be a workout/dance-type of atmosphere. His only request is 4 channels and no budget given because he knows nothing about this.
So, I'm leaning on some of you pro-sound members for PA advice. There are neighboring businesses, so high-SPL is not needed. I would like to see speakers that go as low as 50-60 Hz, a 4 channel amp, and a source that can stream internet content, Bluetooth-connectivity from a phone and accommodate a CD/DVD player input. Of course, this will be a budget system.
What can you recommend, AV NIRVANA members?
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
I am not sure the intentions of needing 4 channels, is she wanting to have speakers at the rear of the room as well as the front?
A two channel amp that is capable of driving 4 ohm loads would work fine all you need to do is get speakers that are 8ohm. Active (self powered speakers) are another option. What is her budget?
Yourkville make a decent 15" speaker but you need an 3/1 octave EQ to make them sound good but I would do that with any system that I would set up. Used may be a good option to save on cash. Often you'll find Yourkville speakers available for less than half price (around $150-200 for a pair) If you want to up the quality Electro-voice (EV) has some nice speakers as well.
As far as a mixer there are several options I would look for an Alesis MultiMix 8 USB FX as it has a usb input for use with any iPod or android device for music plus microphone inputs and you can hook up a CD player and such. As far as Bluetooth connectivity there are plenty of Bluetooth receivers that you can buy that can be hooked up to the mixer on amazon.
Hope this helps
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Thanks, Tony.
I will shop around for a decent mixer (that Alesis looks like it fits the need, nicely), 2 channel, 4 ohm capable amp and 4 passive speakers.
Sweetwater usually has some really good deals on PA equipment.
Back when we were doing Karaoke and DJ services, we were buying a lot of that type equipment.... we had two rigs. We were able to get our local music shop to match online prices in most cases. You might check out your local music store and see what they have. They likely have trade-ins/used equipment on the cheap.
Travis Ballstadt
Administrator
Seattle, WA
Anthem AVM60
Emotiva BasX 5
Emotiva UPA-500
SVS SB2000 x2
They still have those?
I would again recommend one of the Bose L1 systems. They sound great, and they are designed from start to finish to actually serve as a PA and a monitor system, to be placed on stage behind the band. That means they don't feedback. I've used and heard these many times, and it's true. They don't feedback. I would say that should be a huge consideration for a workout studio, as they will likely be all over the place with a wireless mic on, and they're not going to want screeching.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Thanks, Sonnie and Thrillcat.
Sweetwater is a great place and we do have a pro sound shop or two in town that might price match. I don't know if they will want to pony up the money for the Bose system, but I'll put it on the recommended list. Used is probably the most cost effective way to go, especially if I can find 4 like speakers that can be tucked into corners.
welldun
For their needs, I would recommend the EV Evolve 50 system. much like the Bose L1 system mentioned above, it is a small line array system mounted on a sub. Everything including the connections is easy, and the sound is very good.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
Whoa, that EV system looks pretty sweet! Probably more than they'd like to spend, but I will put it on the list, yes.
Looks like, for now, she is going to use the set up from her previous building.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
Vizio E550VL
