Ed Zeppeli
- Aug 30, 2017
- Messages
- 29
Hi all,
I'm setting up my system and am digging in deep on the details here in my attempts to fully understand what's going on and maximize the gear I have. Here's part of the room used for audio...
Behind the camera lense is another 22' of room.
I'm trying to get best results of crossover between the horn modules and 15" woofer module (most importantly) and then to integrate the subs. I'm flexible on moving them around a bit and by using two I was hoping to eliminate some modes in the listening position.
I have a Steinberg Cl1 soundcard, a Behringer measurement mic and a dbx Venu360 for processing. Separate amplifier channels are feeding the horn modules (2), the 15" woofers (2) and the 18" subs (2) for a total of six channels.
I have 8 parametrics per band available as well as another 12 overall on the dbx input side.
Initially I was hoping to use some voltage drive curves which I found for a very similar set-up but I can't get the slope right on the horn module because there is an internal crossover which will not allow it. I'd like to come up with my own slope equivalent to LR24db/octave in the 700-900Hz region but am not sure on how to accomplish this. Delays can also be set on any output in order to time align the drivers.
Attached is an mdat file which includes three listening position measurements for each of four drivers. Subs have been excluded for now.
The soundcard is set-up for loopback and I am familiar with the method for aligning the IRs in REW. Specifically I would like to know a good way of getting the most even alignment between woofer and horn in the crossover region. I saw an interesting idea using Arithmetic A-B and steepening the notch but I haven't wrapped my head around it fully and don't seem to be getting any notch whatsoever.
If anyone wants to take a look at the file and offer a bit of direction it would be greatly appreciated.
Thanks in advance,
Warren
Thanks in advance,
Warren
