klipsh rp-280fa vs chane 2.4
Matthew J Poes
The equipment you have listed is hard to follow. I’m not sure what each piece is being used for but assume you already own some or all of it?
Personally I think the Chane subwoofers are better than the Klipsch subwoofers you have listed. They will play much louder at most it not all frequencies.
As for the main speakers, I am not really a Klipsch fan. I find them on the bright side and prefer other speakers for the same money. Having said that, one mans bright is another mans detailed. Comparing these two speakers is hard. The Klipsch is much more sensitive and is more likely to hit or come close to reference levels. The Chane might as well, but I have my doubts. The Chane I think is the more neutral sounding of the two. I would go for them one if these were my only choices, but know that with the Chane you may need some external amplification to hit reference levels.
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
As we have said before you have chosen some good speakers and each has its pros anc cons. The challenge with giving you an answer is that your room acoustic will change how each speaker interacts within the room so rating them would be pointless. You have a good list and any of them would be an awesome system so make a decision based on what you want for looks and what you can afford.
JBrax
Marantz sr7010
Emotiva XPA-3
Samsung K8500
Klipsch rf-7 II
Klipsch rc-64 II
Klipsch rs-42 II
Klipsch rb-51 II
Klipsch rb-51 II
Klipsch rb-51 II
SVS PB12-NSD (X2)
Panamax M5300
Sony Bravia XBR65-930D
Logitech Harmony One
PS4
Gentlemen, kudos for attempting to answer the question. Take a look at the old site under member name Markyboy14 for some insight as to what to expect in future posts.
Eric SVL
Denon AVR-X4500H
Hypex NCore NC252MP
iLoud MTM
Micca OriGen G2
Sony PS3, PS4
Buchardt S400
Polk LSiM 702
Focal Chorus OD 706 V
Rythmik
ELAC Debut Reference DFR52
Samsung PN64H5000
Google Chromecast
GIK Tri-Traps
Well the only people who can give a definitive answer are those who have listened to both extensively and could write a review on the sound of each. That number is going to be very few, but I'll share a few thoughts.
Regarding Klipsch being bright, the newer designs are less so than the old designs due to using better waveguides, but they are still going to be a more aggressive sound (just maybe a little less than they used to). Also bright does not mean detailed - it just means there is an uptick in the response in the higher treble. There is detail in the bass, in the mids, and in the highs, and I would bet that Chane probably squeezes more detail out of its sound than does Klipsch due to the components used, but Klipsch speakers will not be lacking. I can tell you that I have auditioned the A3rx-c 4 years ago and they are neutral with lots of detail. The midbass and lower midrange were lethargic on my pair so I did not keep them, however, it is possible they did not work well in that room. I did give them 100 hours of break-in. I'm still open to trying Chane in the future as I do like their design, and I am in a different room now. I really loved the planar magnetic tweeter. Best I've heard.
I think your best bet is going to be to read a lot of reviews of each to get an idea of what to expect from them, and consider taking advantage of Chane's in-home trial. Also, I would recommend looking at different subs. See if Rythmik, SVS, or HSU would get you more sub for your dollar. How many cubic feet will these be going into? Do you really need four?
