Issue exporting filters as WAV
luegotelodigo
I tried several times to export filters as impulse response in WAV but doesn't work. It doesn't display any error so I can't give you any more hints.
I'm trying to correct a microphone response by convolution.
Do you mean you don't get any file, or the file doesn't contain what you expect? There may be errors recorded in the REW log files, their location is shown in the About REW box.
luegotelodigo
I don't get any file on W10 but it works on Mac.
Thanks for answering.
Need to see what is in the log files for Win10 then. Generally works, so there must be something specific to the installation or the particular filter impulse response.
luegotelodigo
I will check on Monday (Win10 is at work) but I'm very happy with REW eq. I wanted to correct a M-S pair I used for Lateral Fraction measurements from 100-8K Hz. I measured free field 90º omni (black curve) and dipole (red curve), calculated their transfer function and the filters to make it flat, exported to WAV and convolved with the dipole. The result is the blue curve that fits nice with the black one.
Cool!
