Installation/start-up issues 5.20 beta
martin.atterhall
Hi,
Just found out about REW and am really looking forward to start tweaking, but I'm not able to make it run on my laptop (Win 10). I've tried the different versions, updated Java and keep getting this message.
Any hints on what could be wrong/missing?
/Martin
Most likely an incomplete download, or antivirus software has modified the file. The file is 36,173 KB, check the download is the same length.
martin.atterhall
Thanks for your quick response! I've downloaded again and only get 33 641 KB (identical). AV disabled temporarily. Also, in the download section, the file is stated to be 32,9 MB, weird?
My mistake, sorry, mouse highlighted the macOS build when I was checking the size, 33,641 KB is correct. Just downloaded and installed it from the Downloads section and all behaved normally.
martin.atterhall
Reinstalled, now functional :yes: - I'd apparently messed things up by trying to install in other than the default folder. :whistling:
Curious, seems to install OK to other folders for me but I haven't tried folders outside Program Files.
