Steven Sullivan
- Apr 2, 2019
- 1
Using the Room Simulator, modeling a room that's rectangular (14 ft wide x 14 ft 9 in long) I'm noticing something.... as I move an object (say, the listener icon) along the length there are two '1/2' points with two different graphs, one measured 7ft 4in from the front wall , the other 7ft 4in from the back wall, which is not quite correct (the actual 1/2 point of 14ft 9in being 7 ft 4.5 in). I presume this is because there are no fractional inches allowed? The resulting distance difference between the REW 'half points' is small (1 in) but I'm surprised to note such an obvious difference in the graphs, especially around 40Hz. An accurate half-point graph would be the same from front and back. Can REW add support for fractional inches in the future?
