House curve not being displayed
Mason Dixon
I'm using this jbl house curve in the preferences option in REW. However, it's not being displayed in the EQ window.
  • jbl house curve.txt
dc2bluelight
I tried your house curve file, works fine for me. In the EQ window, to see the house curve click the Target Curve check box, and in the "Target Settings" options make sure you set your "speaker type" option correctly, probably "bass limited" in your case.
quatnguyen
DSP 408
I have the same problem. Nothing change when I swiped the curve from Harman to JBL.txt . It seemed that the curve remain the default. Can anyone help me to solve this.
EarlK
Harman is JBL .
Their house curves are identical ( just different names/labels ).
Therefore, when switching between the 2 curves you won't see any change what-so-ever .
