stero01
- Nov 10, 2025
- 1
- Main Amp
- Arylic B50SE
- DAC
- Arylic B50SE (with Arylic ACP Workbench)
- KEF IQ3 SP3500
- KEF SW2100
Hi everyone,
I need a quick sanity check on my 2.1 DSP integration. The "correct" method I've been given seems counter-intuitive and physically dangerous for my sub.
My Hardware & Goal:
Method A: The "Pro" Method (as taught to me)
I was told my "Logical Method B" is wrong and will fail, specifically because:
Thanks!
My Hardware & Goal:
- Amp: Arylic B50 SE (DSP)
- Speakers: 2x KEF IQ3
- Sub: 1x KEF SW 2100 (Active)
- Goal: Correctly set Crossover, Level, Time Delay, and PEQ in the DSP (ACP Workbench). Measurement with REW.
My Problem: Is this method (as taught me) really the right way?
- Level: Level KEFs AND Sub to 69 dB using 20-20k Pink Noise.
- Problem: This forces my sub's physical gain knob to 75% (from its usual 25%).
- Measure: Use a full 20-20k Sweep.
- Violent Result: The sweep is dangerously loud (100+ dB) in the sub's 20-140 Hz range, rattling my room. I'm afraid it will damage the driver.
- Fix: Apply a massive -21 dB digital cut in the DSP, to finally arrive the 69 dB.
- Level/Measure: Use only 20-80 Hz Pink Noise and Sweep for the sub.
- Result: I keep the physical gain at a safe 25%. Levels match, requiring 0 dB digital cut.
The Core Question
- Time Alignment: REW needs the full 20k-Sweep data from all speakers and the subwoofer to compare their Impulse Response and find the correct Time Delay/Phase.
- Digital Headroom: Method A (-20 dB cut) is the correct "Gain Staging" to prevent digital clipping from future PEQ boosts, while Method B (0 dB cut) is dangerous. The subwoofer has to stay on 75% gain.
Thanks!
