enzima
- Sep 25, 2019
- 2
- Focusrite Scarlett 2i2
- Focal Alpha 50
I made my first measurements with Rew and I'm curious about my data.
I tested my Focal Alpha 50 (nearfield) speakers in the listening position and they give me a headache. My head hurts when I listen for a short time and even at low volume (I've never had problems with headphones and other audio systems. These are my first studio monitors).
The Listening Position
My room is 472 x 380 cm.
Listening Position Check
(Data attached in this post)
Analyzing with Rew in the listening position I see that there is an imbalance between the right and the left signal. This is predictable because I am in a corner of the room. I used a Behringer ECM8000 + Focusrite Scarlett 2i2 Soundcard.
Controller Environment Check
I also checked the frequency response in a controlled environment to exclude any speaker construction problems and the data was excellent.
My doubts
Now, my question is: how can I make the sound less "weird" and more precise while remaining more or less in the same position?
Many thanks for your help,
Alex.
My doubts
Alex.
