final design thoughts on sonotube sub build
dreadknot
outlaw audio 976 7.2 balanced receviver
Crown xli 800 xls 1502
Crown xli 800 , Crown xli 800
crown xls 1502
nvidia shield (2017 model)
PL-89
PL-28II (for sale)
Klipsch RB-81 (sold)
Klipsch RB-81
none
none
none at the moment
none
none
Vizio M55-E0 (2017 model) upgrading to tcl 55in
none
none
none
none
none
iv settled on the design for my new sub build an im going to start buying the parts so
if i go with a Dayton Audio UM15-22 15" Ultimax DVC Subwoofer 2 ohms Per Coil wired to 4ohm an placed in a 18in by 60in
sonotube with one 21in by 5.220in port tuned to 17hz
an powered by a Crown XLS 1502 525W 2-channel Power Amplifier in Bridged 4ohm for 1550watt
with gain knob to full would i get an audibly chuff id be using the 10band parametric eq in my outlaw audio 976 4
receiver
the sub ch has a hi an lo shelf an 8 adjustable bands all 10 can be tweaked for 2ohz to 20khz +3 to -20db an the 8 bands
q goes from .5 to 14 for some fine tuning
an id use REW WIZARD to do it
drawing is a rough concept
54268
dreadknot
crown xls 1502
PL-89
PL-28II (for sale)
Klipsch RB-81
none
none
none at the moment
none
none
none
none
none
none
none
cant really show more till all the parts are bought an arrive the sonotubes are a set back as the shipping cost changed with the company i was going to go with tho they did mention they would when i first look at deco-cretesupply.com
2 x 18in by 60in ran 173.50$ with fedex ground the cheapest at 210$ so 383.5 total not bad i thought for to cabs at less then 200$ each for 8.3ft3 but now is 430.35
an why i didnt get when less i did think i would go up that much that fast at save up to get the amp an driver first was my goal tho i did manage to get the amp while on sale an its on the way right not
so im reassessing wither or not to either go with another company that sell by the foot or to go with smaller cabs
the original design called for an 8.8ft3 with a 21in by 5in port tuned at 17 or even two at 37in long but that would very costly for the ports so one
54627
v1
54628
v2 with one port
this sees like the happy trade off for size to cost as two 18in by
48in will run me 138.80$ with 122.71$ in shipping for a total of 261.51$ with the desired sub do you'll that this would be a good compromise with the one port per cab
these are my end caps to be custom cut by sendcutsend.com
theres two different quotes one is for layered hardwood mdf at .125in that would be layered up to 1in for the port side an to 1.5in for driver side per cab
the other quote is for 1in thick for both sides with a mix of .125in an .5in for the port side an two .5in layers for the driver
54630
54631
im good with the cost as iv had work done by them before but my question is do you'll think the both endcaps for these cabs with these drivers need to be thicker then 1in to 1.5in
or is 1in on both ends enough either way thers some steel outer rods that are planned to be used as like a vice grip to the outer frame that also serve as the legs for the cab
54632
your thoughts
