Feature request: wait for timing reference with loopback reference too
Erwin
Hello, I'm using REW from laptop which stream audio through Airplay protocol into Volumio mediaplayer. And unfortunately Airplay has 2 second delay which lead to tail truncating of sweep measurement, around 6 kHz, when I want measure 20-20kHz. Waiting for acoustic time reference helps when I measure full-range satellites, but doesn't helps for sub measurement. For loopback measurements I have dedicated monitor output which mix all channels and send it into REW loopback. So, please add support of waiting time reference on loopback too.
The timing reference can be sent to a different channel than the one you are measuring, so when measuring a sub the timing reference should still go to a speaker capable of reproducing it. I'll give some though to using a timing reference scheme for loopback connections though.
