I'm using REW with VituixCAD to create equalization filters for JRiver. Jriver wants/needs a filter with nominally unity gain. I import mono filters from Vituix into REW, use REW add offset to data to set 1khz level to 0 db at 1 khz for both left and right channels, then export the pair of filters as a stereo.wav. No matter whether or not I check normalize in the export dialog, the exported filter has an SPL of around 150 db when I bring it back into REW to check the gain. How can this be happening when the original filters had nominally 0 db gain there and less than 20 db boost at the extremes of the spectrum?
Strangely, JRiver is able to play it despite the large filter gain even without Jriver normalization turned off, but there is a large difference between output straight vs through Jriver and non-Jriver output that I would like to eliminate by setting the gain of these filters appropriately.
I guess my question boils down to is there a way to export a filter.wav with a specific gain at the center of the passband?
Thanks in advance for your help!
