EQ Window won't open
starless
Installed 5.19 Beta (OSX). Everything works except the EQ window.
When I click on the "EQ' button (after taking a measurement) there is a brief pause, the main window refreshes but the EQ window does not appear. Went back to 5.18 but same problem.
What should I try next?
There may be something in the log files, they are in a folder called REW in your home directory - the location is shown in the About REW dialog. If something has been logged there please attach the files that include it. After that try clearing your preferences, using the Delete preferences and shut down entry in the Preferences menu.
starless
Hi John,
Deleting preferences and restarting sorted it.
Many thanks!
Mike.
