If I have setup EQ filters in REW should I get the same result, sound wise, if I export the filter settings as text or the filters impulse response as WAV and subsequently use the output in Equalizer APO software?
The text based settings seems quite a bit easier to adjust without having to re-export from REW.
In the REW EQ for measurement window, does the Modal Analysis/Find resonances support REW somehow in making/setting up filters or is the Find resonances functionality just for human interpretation?
