Class A/B vs Class D, is there an audible difference
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
Just recently installed a new Onkyo receiver with class D3 amps.
After a few weeks of use I can say that the sound quality of the D3 amps sound the same as my previous AB class receivers did. I know there is resistance from many old school users but is this justified?
I've seen comments that class D frequency response can not go as low as A/B switching amps but if that was true then why have many high end sub manufacturers been using class D for some time now. I've also read some say class D is noisy but I can't hear a sound out of my speakers unless I crank the volume well past any reasonable levels and sound quality as I said earlier is as good as I've ever heard.
Thoughts?
GFOviedo
My previous Pioneer received had class D Amps, and I did not notice any audible difference with my Denon either. The one thing I noticed was that the Pioneer ran cooler compared to my Denon, Marantz and Onkyo receivers. I'm glad Onkyo made the move to class D amps since Onkyo ran as hot at my fire chimney.
I'm onboard with both of you guys. I can't hear a difference between them either. Perhaps once correction is applied... but not straight when considering equal output.
Now, if you were attempting to power mega-highend speakers? Perhaps a difference would be audible.
leecreek
Eastern North Carolina
Crown XLS 1502
Onyko 50 watt in shop
Airmotive T2's
Chane A2.4
NHT Super 2's
Polk LS/FX
12'Cerwin Vega, BIC Formula12
Samsung Plasma
51"
Too many
AudioThesis
Dayens Ampino
MastersounD Evolution 845, Compact 845, Dueventi
Dayens Ampino Integrated, Dayens Ampino Monoblocks
North Star Design Blue Diamond Integrated Amp
North Star Design Magnifico
Rosso Fiorentino Volterra, Fiesole
Usher Be-10, T-515; Sonner Audio Allegro Unum
Sony XBR-75X940C
North Star Design Supremo, Venti, Intenso, Incanto
When it comes to solid state I prefer A/B over all others. While Class A is supposedly top dog, I don't like the size of the images I get from those I've tried. The image sounds like its the width of a pencil, regardless of what the source of the sound is. With Class D, I find the 'hifi' amps to have a very artificial sound to them, especially in the bass. It is so controlled that it really doesn't sound natural in any way. The sound is rather lifeless as well. I've heard D can be done well, but I haven't heard it yet.
I will say that the Pioneer SC amplifiers seemed to have gotten some good juju. They are among the better units I've heard, especially for a receiver. They still don't compare to a good A/B in my opinion, but they are great receivers with power for just about any speaker you want. I wish all receivers would jump on the Class D technology as it can only be a positive for everyone.
GFOviedo
I agree with you. I think once you go to the "really expensive" and "high end" audio, you will definitely hear a difference depending on your source as well. I did hear a definite difference when I went from my HTIB Onkyo to my Chane speakers, Denon AVR and Emotive amp specially for 2.1 music. If I had a lot of $$$, then I would definitely dedicate one room for movies and another room for music. That's probably something I will never have a chance to do.
MacBook Pro, Custom i7 7700k De-lid 2xAsus1080ti GFX Audirvana Studio Hang Loose Convolver Tone Projects Michelangelo, Pulsar Massive & 8200, LiquidSonics, SoX
I am not real clear on the goal of a class D amp... I think they sound pretty good for low frequencies (read tight/control) and some what dry or un-life-like in the higher frequencies... I like the sound and sweetness/warmth of class A and A/B amps... And the right tubes in the mix can make a huge difference in performance(read soundstage/presence)... I am also a believer in hurling watts of power thru lots of copper sounds the best... It seems to knock the edges off...
Tony V.
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
Class D amps are far more efficient and run much cooler than A or A/B
Efficiency at the cost of quality of sound it seems... After review of a few design papers it appears to me that a typical class D amp (cut to chase) takes an analogue signal, converts it to a digital signal, adds gain, then filters it back to an analogue signal again... Several gremlins creep in caused by many tesla, maxwell and faraday issues...
Tony V.
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
I dont know if I can agree that quality is lost as so far I am very impressed with the Class D3 amps I have in my Onkyo and believe me I was very hesitant on getting it because of the mixed reviews.
I agree with the latter ... more power always seems to sound better!
AudiocRaver
Senior Reviewer
North Carolina, USA
Onkyo TX-SR705 Receiver
Phantom Center
NSM Audio Model 5 2-Way (x2)
I have not been able to hear a difference that was "digital" vs "non-digital." When I have been able to tell a difference between two amps, and had the opportunity to try to explain it, there has been a measurable spec or characteristic that did so. I am a believer that audible differences between amps can be measured if we know what to look for and how to measure it, although there are certain to be exceptions. So I guess I will enter my plea as "there is no digital sound," just audible, explainable differences between amps.
This is no doubt a difference in heat between A and A/B. We thought something was wrong with one of my Emotiva XPA-1 monoblocks, but discovered one was set to A, and it was extremely warm. Not warm sounding... no... warm to the touch. Can't say the right speaker was any warmer sounding than the left. :bigsmile:
Matthew J Poes
I'm with you Wayne. The reason a lot of Class D amplifiers sounded bad in the past (and some still do) are due to very measurable problems. The most common are current delivery and high frequency oscillation.
Another problem has been that the filter coming after the feedback and causing instability and response variation with load.
There are a number of "class D" amps such as those from Hypex, ICEpower, and THX which offer near perfect measured performance and totally neutral sound. They even have been noted for their tube like sound and there are measurable reasons why that might be. These amps have nearly no distortion including switching distortion and as a result do not suffer a rise in high order distortion that most amps with a lot of negative feedback would have. Most tube amps have very little negative feedback and so whole they have higher overall distortion, it's largely benign 2nd order with very low high order. Often lower than their solid state equivalents. They are also often either class A or biases such that they have pretty low zero switching distortion.
I personally love Hypex amplifiers and use them in my system.
Matthew J Poes
Pioneer has had some magic amps for a while for some reason. They had some receivers for a while using what looked like a cheap basic chip amp but both measured and sounded really decent. Not Krell amazing, but very good for sure. The SC series used icepower and D3 which was pioneers own class D design. The story I heard was that their engineers were asked to benchmark the icepower models and better them. I imagine it was a cost savings choice as well, but if they could better the performance for less, that's not so bad.
I agree that receivers should all go Class D but only if it's of the Ilk of ICEpower, D3, Hypex, THX AAA, etc. There are still a lot of class D amps out there with compromised performance. I'd rather not see those proliferate.
AudioThesis
Dayens Ampino
Sony XBR-75X940C
I disagree with your first post Matt, especially the comment about D sounding like tubes. Never have I thought that. I've still yet to hear Class D sound natural, but I have heard several A/B amps deliver in that category. The better Class D amps I've heard get the tone right, but nothing about the presentation is correct. Your mileage may obviously vary. :)
Matthew J Poes
Have you heard the Theta Hypex NCORE amps?
http://thetadigital.com/prometheus_amplifier_info.shtml
These use the NCORE modules with a really good power supply and front end/input stage. If you haven't, they just might change your mind about Class D.
I'm not unique in thinking Class D sounds tube like, but as you say, your mileage may vary. Take a listen to the Theta and see if you don't at least find a better overall presentation.
These Nord amplifiers sound nice as well:
https://www.nordacoustics.co.uk/nord-one-hypex-nc500-se-stereo
Based on the same family of modules, though a bit more off the shelf. These are the amps that got me to built my NCORE NC400's.
tesseract
Lincoln, NE
Emotiva XMC-1
Emotiva XPA-2 Gen 2
Emotiva XPA-3 Gen 2
Dayton SA1000
JTR NOESIS 210 RT - L/R mains
Chase SHO-10 - Center
Chase PRO-10 - Surrounds
Vizio E550VL
Yes, I noticed a L/R heat disparity. I can not say I heard a difference.
Matthew J Poes
Hah, you guys are too much. Having never seen any deep inspection into this concept I cannot say too much, but I read an article that talked about the recent rise in amplifiers with class A switches. What these do are to raise the bias voltage to a high enough level to force the amp to operate into Class A up to a higher wattage. They are still Class A/B amps, but operating as Class A into the 25, 50, sometimes even 100+ watt range. The author was an electronic circuit expert who designed amplifiers for the audio industry and he felt that these are compromised circuits in this setup and actually sound worse (if different at all). He really felt such amps should be left in their class A/B setting. That to really hear the difference a true Class A amp makes, you need an amplifier designed as a Class A amplifier outright, something more like the Pass amplifiers. There only real advantage is a reduction in switching distortion which would only be audible at very low levels of information.
