[Bug] Graph Limits not remembered
3ll3d00d
using the latest beta on linux, I get the following behaviour
* import a couple of wavs
* select the 2nd one and go the SPL & Phase tab
* change the graph limits
* go to the 1st graph
* return to the 2nd graph
* graph limits have reverted to the original settings
If the axis settings are such that a selected measurement will not have any part of its response within the graph the graph will be shifted to make it visible.
3ll3d00d
OK, makes sense however it's still a bug, just a different one because it didn't occur to me to add one extra piece of information :)
That (auto update axis range) feature is not respecting a display only offset (i.e. one which has not been added to the data).
