- Jan 31, 2020
- Messages
- 53
- outlaw audio 976 7.2 balanced receviver
- Main Amp
- Crown xli 800 xls 1502
- Additional Amp
- Crown xli 800 , Crown xli 800
- Other Amp
- crown xls 1502
- nvidia shield (2017 model)
- PL-89
- Center Channel Speaker
- PL-28II (for sale)
- Surround Speakers
- Klipsch RB-81 (sold)
- Surround Back Speakers
- Klipsch RB-81
- Front Height Speakers
- none
- Rear Height Speakers
- none
- none at the moment
- Other Speakers or Equipment
- none
- Video Display Device
- none
- Screen
- Vizio M55-E0 (2017 model) upgrading to tcl 55in
- Remote Control
- none
- Streaming Equipment
- none
- Streaming Subscriptions
- none
- Satellite System
- none
- Other Equipment
- none
for driving a set of Dayton Audio RSS460HO-4 18" Reference HO Subwoofer 4 ohm in a ported cabinets which do you think would be best suited for powering them
either a Crown XLi 2500 750W 2-channel Power Amplifier or the Crown XLS 2502 775W 2-channel Power Amplifier
in a layered ported cabs tuned to 21hz with either 750watts at 4ohm (xli) or 775watt @4ohms (xls) an a 4th order high pass at 16hz from my outlaw audio 976 receiver
with a 44in long 12in wide 2.5in high flair port
the walls of the cab will be 1.5in inner 1.75in port wall an outer wall of 2in thick
with an net ft3 vol of 3.8cft
so with walls this thick an a epoxy resin coat in an out i dont think id need any extra bracing
the inner cab dims would be 35in h by 16.7in w by 12in d
outer dim 38in h by 24in w by 15in (1.5iin front an back panels with a .5in flush cut for the driver)
i plan to build two matching cab an run off
whichever would be better with load an sinad
you thoughts including paint on color
