Beginner need help from professionals
vojvoda
Hi I apologize if I violate any rules but have long wondered if it is possible to get roomeq to generate EQ filters so I can apply those in Marantz built-in EQ that looks the following out
+ 6db
63 Hz 125hz 250hz 500hz 1khz 2khz 4khz 8khz 16khz
-20
Because I own no DSP, thought to try if roomeq can figure out filters for those points only and how do I do that in such cases
Afraid not, but you can adjust the filters manually by playing the Pink periodic noise test signal and watching the response on REW's RTA with these settings:
23117
