Marzolino
- Passive Line Level crossover with Vol and Bal cont
- Main Amp
- Adcom GFA 545 for woofers
- Additional Amp
- NAD 2140 for midrange
- Other Amp
- NAD 3120 for tweeters
- Cocktail Audio X35 Music Server
- AR 3A Improved multi amp connected (NO int. xover)
- Other Equipment
- Beheringer DEQ 2496 Equalizer
As one only measurement is not enough to get a valid EQ I use to make 4 measurements, around an half circle centred on the loudspeaker. So I get four measurement files that I name Meas-1, Meas-2, Meas-3 and Meas-4 and then I proceed as follows:
The last file AVG 4Meas could be the average of the 4 original measurements, but is it true? I doubt that the procedure is correct, I'm afraid that the last “AVG 4Meas” doesn't save all the information previously held in the original single measurements, including SPL, distortion, phase, IR and so one. Wath do you think about?
Another way to get an averaged measurement could be, I think, to merge the single filters derived from each measure, and calculate the average filter. Is there a way to get from 4 filters one single averaged? Some ideas about it ?
Thank you to everybody
- open Meas-1 and Meas-2 in the All SPL window , generate the average (A+B)/2 and save it as: Meas AVG 1+2
- open Meas-3 and Meas-4 as before, generate the average (A+B)/2 and save it as: AVG 3+4
- finally I open the Meas AVG 1+2 and Meas AVG 3+4 and generate the average saved as:AVG 4Meas.
