mamba76
- Lenovo M8 FHD tablet
- Main Amp
- JL Audio XD600/6 (front end)
- Additional Amp
- JL Audio XD400/4 (midbass)
- Other Amp
- JL Audio XD1000/1 (sub)
- Streaming Equipment
- miniDSP 2x4HD feeding C-DSP6x8
- Focal Utopia (2003 model) (6W2's + TN51's)
- Surround Back Speakers
- JL Audio ZR800s (pair)
- JL Audio 13W3 4ohm
Hi all. Been a while since last post but revisiting my SQ system again. Seems I cant just leave it alone!
Setting up a car for sound quality is a struggle as there are so many elements involved but having the right tools for the job can make life easier.
I dunno about everyone else but I find having a custom target curves (one overall curve) and also one for each driver (I have a four way system, sub, midbass,mains,twts) has helped take out some ambiguity about whats happening on the crossover points (roll ons, roll offs). It just helps relate what I see on the graphs with what I hear.
REW has target curves built in and you can changes these by changing the text files. But it takes so much time and effort to create a complexed target curve. For instance if a wanted a straight line say 40hz 90db to 300hz 74db, simple right? no it gives you a big curve. I know this is designed this way for a reason which makes sense but I just want a crude and simple way to fully customize and easily create and alter a curve and put that in a frequency response that REW can use. Id use paintshop if I knew how to correlate that to a logarithmic scale. Say you want to up the bass a 300hz wouldn't it be absolutely brilliant if you could just click a point on your target curve and drag it up a bit, then save it!? Eureka!
I know Im crude and unconventional but custom curves help me big time.
