- Dec 29, 2020
- Messages
- 844
- Yamaha RX-A3060, RX-V1900, RX-V1075
- Yamaha BD-S681, Sony UBP-X800, Oppo BDP-83
- PSB Image T65, PSB Century 800, PSB Century 300
- Center Channel Speaker
- PSB Image 8C, PSB Century200, PSB Century 100
- Surround Speakers
- PSB Image 1B, RBH A600, PSB Alpha Minis
- Surround Back Speakers
- PSB Image 1B
- Rythmik LV12-R, PSB Subsonic 6, PSB Subsonic 5
- Video Display Device
- UN65KU6491 65"/UN55MU7000 55"/UN50MU7100 50"
- Remote Control
- Logitech Harmony 650
- Streaming Equipment
- BlueSound Node2i
Here's the entertainment center with cassette deck. The bluetooth attached subwoofer sits between the left hand side of the recliner and behind dining room chair against the wall. I've been resting the soundbar across the open cabinet doors and I was tired of the rats nest of wiring that was there so I attempted to clean some up.
The before shot:
I ordered some floating shelf brackets but the dimensions on the plate that gets fastened to the mounting surface wasn't given so I took a chance and ordered them off of Amazon. I also out rerouted the wiring and orderd a 15 ft optical cable and routed that back up from the cabinet to behind the display.
That little box with the redlight on it is an ADC that converts analog out from the deck to digital TOSLINK so I can connect it to the soundbar. When using it, I have to unplug the HDMI out or it bypasses the TOSLINK input. I can live with that inconvenience. The only issue is that I can't open the cabinet doors all the way as the mounting plate of the floating shelve cabinets are two thick as shown below;
I found a pair of 14" right angle brackets that I'm going to mount behind the TV. I checked and I have enough wood back there to go up 14" behind the TV on either side. It will also finally be tall enough to open the cabinet doors without the tops rubbing against the underneath of the sound bar. I'm waiting on the order to come in.
Here's the sub location;
It sounds good at all the seated locations.
The before shot:
